CM3 Pressure Monitor - Specification - External Construction
Use this button to return to the Specification Overview
The CM3 is supplied in a rugged case to withstand the conditions it will meet during it's working life. The case has an internal O ring and pressure seal to keep out the elements when the unit is being stored or transported. It has thick walls to resist knocks and abuse and will not dent or corrode. Recessed areas allow individual distributors or equipment hire outlets can add their own logos or nameplates.
- The case is injection moulded from a tough ABS plastic alloy which will withstand a 900Kg stacking load.
- Non-metal construction will not dent or corrode and the colour will not scratch or rub off.
- The case can be completely submerged without water damaging the CM3. *
- The case stacks for easy storage and comes complete with a carrying handle.
- The hinge runs the full length of the case and has a stainless steel pin
Building sites are difficult environments and to operate successfully the pressure monitoring equipment must have the best protection. The CM3 case gives this protection and is designed to look good for years.
*the case must be closed and the pressure relief valve closed before the unit is submerged.
